6n2 rear seats
I have got the bottom of the rear seats out of my 6n2 but I can only get the backs of the seats half way off, I don't understand the fitting, could someone help please!
The middle has a clip on either half of the split folding bit pivot thing, small lever bar or a flat bladed screw driver should remove these.
Outers I believe are like a door latch, you might have to push the catch across and lift the seat out at the same time
Bit hard to explain tbh
As above look at the centre mount bracket there should be an opening and inside there should be metal clips, just remove these, and the others you already got off. If it proves difficult I think that the centre mount is bolted to te floor ao you may be able to just unbolt the whole thing.
HTH
Thanks guys!
