6n2 sills
What it the size diffrence between the 1.4 and the git sills, also could you put the git sills on a 1.4??
  • Views 1.2k
1.4 16v came with the same sills as the GTi. The 8v has the same "rounded" sills as all the 6N Polos. It is possible to fit them but you're talking two full sill replacements. Not a light task and only something worth doing IMO if the sills need done.
I did it on my 6N and the sills were not an exact fit but if you're not doing it yourself you wont worry. Check out my thread for pics if you want.
A kid hit mine with a skateboard n put a bit dent in it so just thorght I'd change the sills if it was an easy job but if it needs cutting I'll just have it pulled out n painted.
Edited by milky321
pulled and painted isn't even half the job. it'll be cheap compared to changing sills.
