Mk4/6N Clocks SORTED
As cheap as possible as I'm just going to take them apart, don't mind broken plastic faces. Cheers
Edited by kerrly
  • Replies 15
  • Views 819
got a set of early 16v clocks that came with a conversion, £15 posted?
Edited by Mclovin
some 72k ones? 13 posted
standard 6n ones £12 posted
Do either look like this one?
i dont think so, they are from a 96 polo, think they are the later spec clocks but ill have a look.
I'm after 'late' clocks. Thanks
yeah there 96 same as mine pity your in rush 4 them as mine will be no good till me when i do the dash swap
I'm not i a massive rush, my Polo only has suspension and brakes fitted to it :lol:
well send me a message when you need them and if i have them out you have the, 4 thre price of the postage :)
Iv got a set of later clocks, around 78k.
Have removed warning buzzer but may have it somewhere, Airbag light + oil light also blanked but easily reversed
You can have them
You can have them
I don't mind if they don't work, i will never use them. I just going to chop them a bit and my Mk2 clock surround and spare plastic cover to see if i can fit them in my Mk2 and be able to see all the dials etc
PM me what you want to post them.
bump
bump
I've got a set mate:
I'm after the late style.
