window tint
hi guys/girls I've had some window tints put on my rear windows and there are still some air bubble that i carnt seem to remove could someone give me any tips on removing the air/water bubbles
many thanks jamie
  • Views 880
Were they DIY or company fitted?
Tiny pin would work but leaves a hole. Other method is to "chase" the bubbles to the edges using a credit card or the proper applicator. Failing that its remove and start again.
If a company did it then take it back.
Also don't use the rear window heater for a few weeks as it can cause the adhesive to unstick and create a stripe of bubbles along the wires.
they were diy done first time doing it turned out well at the top just a few bubbles at the bottom and thanks for heater advice :D
That's why I lay it on wet, no bubbles anywhere best bet is do it again if it's bad if not yeah prick with a scalpel and sqeegee to the centre of the prick
Because of the curve on the rear screen you have to slightly melt the tint with a heat gun when you put it on. It takes a lot of practice.
okie guys thanks for the advice got a few out today they just pushed out :D but need to do more work on them
