Towing a vehicle
For driver licensing purposes there are no vehicle/trailer weight ratio limits for category B+E.
Is'nt there some restrictions on towing speeds? depending on the weight of the item being towed in relation to the weight of the tow vehicle if it's less than 75% then you can tow @ 50MPH greater than 75% then your limited to 30MPH and if the trailer is unbraked there are also speed restrictions??
towing speed limits (unless signed otherwise):
30mph for built up areas
50mph for single carriage-ways
60mph for dual carriage-ways and motorways
your owners manual might state lower towing speeds according to weight.
  • Replies 28
  • Views 2.6k
If you took your test after 1997, a catagory B entitlement only goes up to a 750kg trailer.
thats a common misconception, i thought it was the case until i did a bit of research and contacted the dvla.
Those restrictions I mentioned were in force when we used to have a caravan back in the late 70's but it seems they are no longer in force ??
Found this http://www.batesontrailers.com/trailer-tow...ilerTowingSpeed Gives a guide on weights and licence requirements
i wouldn't be surprised, speed limits don't change often and the speed limits i mentioned are still in force. ;)
here's a link to the directgov website.
directgov
edit: i know what you're saying about about the weight ratio of the car and trailer but i can't see any further restrictions regarding speed limits.
Edited by polo45
