window wont work.
my drivers side window will not work ( electric) the switch lights up so its still getting power and u can hear ut make a noise but nothing happens , anyone had this problem ?
  • Views 712
Motor gone.
when you buy another grease it up!
The switch has it's own feed, so it's not "getting power".
Check the wires behind the sheath on the door for breaks. Sometimes the window slides off the runners, or gets moved slightly. Trial and error to get it repositioned so the motor can lift it.
Try and fill the cables with grease.
