Water leak
HI guys, been having some problems with a water leak in my open air. After heavy rain there is a small amount in the passenger foot well it seems to dribble down next to the dashboard. Also when i pull away or corner it gives a nice shower to my passenger through the grab handle amusing but annoying. Are there any drainage holes that may be blocked? Or could it be the roof itself as there are small tears at the rear of the roof. Any help appreciated, cheers
  • Views 816
Afaik there aren't any drain holes which is a design flaw but hey. best way of testing is to use a hose or bucket are the reared area and if there is a raised part this is most probably it.
Iirc the roof should close flush and this is the seal so again any parts that aren't seated right are probably letting water in.
Okay thanks for that will check all the seals, kind of gone down in my priorites now though as my gearbox has just gone boom. Not cool
Pretty much the exact same happened to mine a month and a bit ago. My neighbour helped sort it out but along the line of the sunroof part there's a little hole that ends up running water into the passenger stairwell. Fill up a jug with water, put a towel in the stairwell and try to find the hole on the sunroof. I think it's in one of the corners. When you find it, use some of that white rubber sealant stuff you use in bathrooms to watertight them and block the hole that the water's getting in. Don't hold me to my word though, it's just a similiar situation to mine :)
