56cm knight rider effect led lights
brand new never used - like pic below but led strip is black !
comes with neat remote and sensor box - easy to fix!!
this is the newer version which comes with more choice of colours and functions-
Specification:
There are four buttons, namely A, B, C, D on the remote fob.
•Button A (Right-bottom): Deceleration (each press will decelerate for 1 level. Total 10 levels of speeds)
•Button B (Right-Top): choice of functions (15 flashing modes)
•Button C (Left-Bottom): acceleration (each press will accelerate for 1 level. Total 10 levels of speeds)
•Button D (Left-Top): switch on/off
Features:
flashing modes
Adjustable flashing speed
Remote control via a fob
Super bright
Long-lasting
Water proof
Features:
1. 20 scanning modes, trailing effect, adjustable scanning speed.
2. With power failure memory function (when the power is turned on after cut off, the mode setting would be the same as before the power turn off); the modes will take turns in sequences automatically. You may select and set a certain mode as well. All the functions are controlled by the remote.
3. New function: with an extra positive wire, which can be connected to the car braking light circuit. Regardless of the mode, the light will flash violently as a warning when braking. (This positive wire could be connected to the door switch as well. The light will flash violently when the door is open.)
bit like this
£15 posted - no offers!!
thanks.
  • Views 227
you have pm
anyone? these are still available!
