308mm/288mm brake setup to fit 86C Polos!
Calipers, carriers (with slider bolts), and used pads (nearly new) for a 308mm front brake setup to fit 86C Polos. Get some shoulder bolts as per the 256mm Vauxhall conversion and these bolt on.
£100ono.
Proof that they fit a Polo strut:
The Vauxhall boys use these with either 308mm discs (16" rims) or 288mm discs (15" rims). I'm told that some Meriva diesel 288mm discs are 4x100PCD and work with these calipers and carriers too, but I've not bought any discs to try!
  • Views 207
Sold.
