Head unit won't go in dashboard far enough?
I recently tried to fit a Head unit into the dash of my '94 Polo matchcoupe and it wouldn't go in far enough to sit flush with the dash. Is this normal or is the head unit to deep for the dash?
  • Replies 11
I'd say your wires are bunched up at the back, put your hand up under the dash and pull it all through. Have you got lots of wiring or a large ISO connector close behind?
That's what i thought it was at first. It seems to a large triangular piece of plastic in the back of the dash that stops it. :?
i had to cut a bit of plastic out to get mine in even then it was a bit further out than i would of liked.
Edited by polo45
That's what i was thinking of doing. How did you go about cutting it out?
When i removed the bit of plastic i used a dremel it was lucky i had the extension bit to go on the dremel or it wouldnt have gone in the hole.
i trimmed a bit of the heatshield off the back of my headunit.
if your using an amp set up you dont even need the heatshield on the back so you could take it off
It hasn't been trimmed in this photo
and if you take it off you're left with this,
you can just wipe the paste off
Edited by twitch4685
Flat blade screw driver and hammer is how I removed that bit of plastic lol
Curse of the Mk3.
I've used the hot knife attachment on the end of a gas solderring iron before. Wee bit risky though.
Thanks for the help lads, I'll give it a go later. :thumbsup:
Had to same problem, Still meaning to sort it out, As mine hangs out like a cm!
Mine was a bit of a squeeze, although I did manage to get it in once I had cabled tied all the cables out of the way.
