need a cam shaft pulley from all polos mk1 onwards
I need Cam shaft pulleys for all Polos from mk1 onwards please
  • Replies 10
  • Views 507
Not sure what you mean. Do you want a square or round toothed one?
May have a round toothed one lying around.
I have one in square tooth flavour if you need it.
what MK polo ??
well i want one of each from each engine
Well I have a round tooth somewhere
Like prankstar said in the other thread, theres only 2 different cam pulleys accross the range.
Square tooth and round tooth
Mine comes from a Mark2, engine code MH. Though that doesn't necessarily mean all Mark3 engines have the round-tooth set-up, as early '90-'91 engines used some of the left-overs from Mark2 production. My GT lump came from a '92 squareback, but had the square-tooth set-up. I believe a fair few G40's also run the older set-up. You just need to confirm which set-up you have and one of us should be able to help you :-).
i have a mk4(6n) one from 1995 pm me its for sale and will post
There's actually 3 types (at least 4 if you include the diesel engines, which I will not)
square tooth mech head mk1/mk2
square tooth hydro head mk2/very early mk3 (N.B. some very early hydro heads still use the mk1 type pulley so I'm told)
rounded tooth most mk3/mk4 etc.
I have quite a few of each
