Rainbow CMX465 Speakers
Very good condition, comes with grills not shown in the pictures.
So so loud, yet so so crisp. Truely SQ speakers for a classy looking show install.
Spec:
6.5" (165/170mm) 2-way component system.
◦Component speaker system includes woofers, tweeters, and crossovers
POWER specifications:
◦200W RMS power
◦Sensitivity:90db
◦Frequency response: 45 - 23.000 Hz
◦Crossover Frequency: 3.200 Hz
◦Mounting depth without / with ring: 65 / 63 mm
TECHNICAL INFORMATION:
-Woofer/Midrange◦Folded, powder-coated steel basket.
◦Chromium-plated terminals for high quality cables with large diameters.
◦Extremely flexible surface refined lead wires.
◦Butyl rubber surround for controlled cone motion.
◦Despite use of aluminum compound cone on a polymer cellulose base, authentic sound reproduction.
◦Innovative concave dust cap for best frequency response.
◦Powerful vented ferror-ceramics magnet for improved magnet motor cooling.
◦Linear vented Nomex spider to prevent compression problems.
◦High temperature, vented Kapton voice coil former for minimal current loss
Tweeter
◦Tweeter dome of special titan compound.
◦Neoprene surround for controlled motions.
◦Vented voice coil former with stainless steel lead wires.
◦Ferrofluid voice coil cooling.
◦Powerful neodymium magnet.
Crossover
◦The CMX crossovers are placed in showcase housings. Premium quality parts, including air coils and MKT capacitors, ensure the perfect sound performance, while chromium plating enables the best possible connections. The variable tweeter attenuation level with reversible thermal protection prevents excessive treble output.
Pictures fitted in my car
Here is what you recieve
In my current vehicle, i have the 2 components up front with tweeters behind the wing mirrors
the other 2 i have in the rear door cards.
Collection from Taunton Somerset - £140
Posted - £150
Thankyou.
  • Views 221
How much for one set? Pm me please
It is 1 set.
You can't split them.
There's 4 speakers, 2 per crossover and 2 tweeters, 1 per crossover
Would you run these off two channels mate ?
Yeap they would be off a 2 channel mate. You could also run them off a 4 channel if you bridged the channels into pairs.
