6n 1.4 8v engine, gearbox, 4 branch
Ok so I'm selling the engine that's currently fitted to my polo. It's a 1.4 8v unsure on engine code but I will get it. 90k
I will split any parts needed off the engine ie; started motor ect
Post what you need for a price :)
Also have a 4 Branch fitted removed ready £70 posted
Pics soon available
  • Replies 18
  • Views 522
hi mate, how much for the gearbox and what code is it?
cheers,
George
cheers,
George
£70 picked up and I will check the code for you when I get to the garage
Dan
10F89DC2-9A41-443F-B5BE-FA0189429345-281
3D801273-D4FF-4835-B0D0-A08DD1165BB1-281
F63182CD-3FC3-48FE-BD45-C43CFEEAC34A-281
D58B35FC-B9E7-43EE-AE75-8F5174E3F1C9-109
Engine code is AEX
guessing the 4 branch wont fit a mk3?
Hey how much is the engine?? and would the gearbox fit a mk2/3?? if so very intrested??
Was there any problems with the engine?? and has it got good service history??
Thanks alex
What's the cheapest you'd take for the 4 branch?
Thanks alex
From what I no yes it would fit buddy
£110 for the engine it's had no problems only removed for a conversion 90k. Always home serviced with the best bits.
I'd take £60 but that's collected
Thanks alex
How much for the gearbox and the engine?? and ill just make sure they fit if so id be very happy :D...
Has The Engine had any work to it new bits or just serviced?? and is the gearbox good no noises easy to select??
Thanks Alex
Thanks alex
Thanks Alex
For the engine, gearbox and starter motor £200.. It had the cambelt, water pump and plugs changed and regular service. The gearbox is good, no noises what so ever
Thanks alex
Thanks Alex
will i get the wiring loom and ecu??
Thanks alex
Thanks Alex
Ecu will be included but the loom was shot I wouldn't include that just for the fact I'd feel responsible if anything happened
Got any pics of the 4branch?and will it fit the 1.6 8v
Gearbox sold.
Really need the rest gone as I need the room for my donor engine now
pics of 4 branch please and will it match up to a standerd cat?
Pms replied
Hi mate, Just wondering if you still have the Engine mounts, especially the rear lower, and if you still have them if you'd sell them separate to the engine?
