ignition barrel
can the ignition barrel be removed from the steering lock and then swapped into another steering lock ??
if so how easy is it and has anyone done it before
  • Views 861
  • prankstar2003
    prankstar2003
    Yep, totally possible. Remove the lower cowling and there will be 2 allen headed bolts and a rivet type thing (shear bolt iirc). Undo the allen bolts and then you can wiggle the shear bolt loose. You'
What you stolen now mate? Haha
I've not stolen anything...... honest :ninja:
i need to replacing the locking set on my loon and the steering locks and the mk2 and mk3 are different and i need to swap over to the mk3 one so i can do a dash convertion because the stalks have a different bolting pattern than the mk2 stalks
Yep, totally possible. Remove the lower cowling and there will be 2 allen headed bolts and a rivet type thing (shear bolt iirc). Undo the allen bolts and then you can wiggle the shear bolt loose. You'll also have to loosen the clamp for the steering column to get that free. You should then have the steering column and ignition barrel free. You may be able to get the barrel off without the column, but I just removed the lot and didn't look into just the barrel
