mk 2 filler neck area
Hi guys
Had a bit of rust just infront of the drivers side rear arch, took a wire wheel to it today and theres a hole:((( so gonna take it of the road and weld it ( other work is needed any way ).
What I wanna know is, can I get that area of the car as a panel? Sill or arch etc
Oh and of any one has done this job before and.wants to shed some light on the best way to go about welding area that would be great lol
Cheers guys
Pic to come
  • Views 798
Pic
  • 10 months later...
bump
bump
I would try and split it from the rear lip, can sometimes be difficult without damaging the rear lip
You want the rear one to be in tact though because you'll need to weld your new one to it
Other than that its not that hard, just cut it out and make a repair section from 0.8-1mm steel
Cutting it out carefully and matching your patch to what you cut off is your best bet.
