WET FOOTWELLS
Hi,
I have a 2002 1.2litre VW POLO (5 door), which I love however when it rains I get wet foot-wells, I have dried them out many times but it keeps coming back. I have also changed door seals but just checked today and water is still getting in just as bad as before. There is no sign of any water anywhere else in the car (seats are dry etc), can't see any drips or anywhere where it could be coming in?
Please help!!
Thanks Hayley
  • Replies 12
  • Views 3k
do you have a sunroof?
when my footwells were wet i had to change my heater matrix in my car.
scuttle tray
my 6n footwells were both sopping, ended up being the door seals & membranes, once those membranes come off, you need new ones, if they rip, your screwed, might be worth taking the door card off and having a look
Wear wellies.
Maybe worth feeling the underside of the dash for moisture.
Due it being when it rains I doubt it's the heater matrix, unless there's some kind of seal between that and the elements. I'm unsure on a 9n though.
i have the same problem,
i thought it was the scuttle tray or door seal but turns out its the window seal,
water is hitting the seal at the top of the window and running down it and going behing the wing mirror inside the door
then it is flowing out into the footwells.
check your seals still have a strong grip on the door
also look for something like this, if not it could be something else
hope this helps :)
Edited by x-luke-b-x
I would try the scuttle tray first mate one of the easiest things to check and I would say the most likely tbh just take the wiper arms off and prise it off look in the corners near the front wings and take out anything like leaves that you can see :D
get an ozonemaster to remove the damp smell after
www.ozonemaster.co.uk
I brought a car that had a horrible stench, nothing got rid but ozone...
I have managed to secure a discount only for CP members using code--- MAN1210
10% DISCOUNT
Hi,
Please help!!
Thanks Hayley
did you fix it yet? got the same problem gonna try all the above first!
  • 7 months later...
I had this happen to my 6n, drove me nuts till I noticed two holes in front of my sunroof when it was open one day, they are the water run out and go down the a-pillar and are meant to run out of the door and harmlessly away, but vw put an overflow into the cabin if they get blocked up for some reason, bit of curtain track wire down mine cleared out a load of shit and dirt and never had the problem since! :D
Check the Scuttle tray (the bit under the windscreen, you need to remove the plastic covers)
My girlfriends clio was leaking in, both footwells were wet. Turns out that the scuttle tray was swimming with water and was leaking either into the heater pipes or just through the bulkhead.
A blocked drainage pipe was the cause, you know one of the pipes that just go downwards from the bulkhead, they have a little flap on the end, just shove your finger through and get covered with water.
