1 6n2 gti engine piston
pretty much as topic state maybe you fooked an engine i just need one piston, doesnt need rings or rod just the piston
Let me know what you got :D
cheers JOSH
  • Views 481
I sold a load of 1.6 afh conversion stuff to this lad a while back http://www.clubpolo.co.uk/forum/index.php?showtopic=279481
In with it were a set of avy 1.6 pistons that couldn't be used because one or two had cracks due to valve contact. He very well may of chucked them away by now but it might be worth messaging him anyway just on the off chance he does still have them knocking about
pretty sure i have one...£20 delivered?
i got one off a 6n 1.6 not sure if it will fit but let me now and can post, tbf if the guy above has correct part its a safer bet
I'm sure there all the same though
Yours will be a 8v engine and the one above is 16v, the piston are different
I know i have one...so you just need to pm me if you want it 8-)
just checked this thread as haven't managed to get on here all week, and i think I've got one sorted :) ill let you know though if i need one
cheers Josh
