Mk3 leak issues
Okay so I knew about the leak in the boot when I bought the car. Still having trouble sourcing it... It almost looks like its coming up through the rear struts?! Even when stationary. I have tried shoving the hose under the rear arch and nothing came trough. Could it be the rear window leaking onto the parcel shelf and then down onto the struts???
It's a 93 bread if that helps at all. Also, just discovered a wet patch in the footwell too after the heavy down pours. Seats appear to be bone dry.. Any clues?
  • Views 1k
I've just come across this in mine(93 breadvan). Never noticed it before, was soaked yesterday though!
Remove the battery and check the tray for any holes, they like to rot on these cars and when they do they let in water
Hi battery side looks okay water was polling in the the other side so drilled a drain hole into the engine. Also some wiring going down a large hole on the non battery side... Looks like it goes in the car. Temporarily put blue tack init. Is this supposed to have a rubber grommet or something in it?
QUOTE (mikethebike @ Wednesday 26th September 2012 - 9:24am)
QUOTE (jprm89 @ Tuesday 25th September 2012 - 7:45pm)
also the passenger footwell was a bit sodden.. any ideas there again would be helpful!!
If you open the bonnet and follow the bonnet release cable up the right hand side of the bay to where it enters the interior, (at the opposite side of the scuttle panel to the battery tray) you will find that there is a rubber grommet that seals the interior from the water that lays up in these areas of the scuttle panel. In your case (and my case) the rubber grommet will be cracked and perished, and the steel surrounding it will be rusted.
This isn't a solution, i'm just telling you were the water is coming from.
same place (i think), thankfully mine is'nt rusted.. there is just a gaping hole with two wires running through it... no grommet at all!!
iv put a small drain hole into the engine bay to stop any water pooling in there like it has been. hopefully this will help with the general issue as well. covered the hole with some blue tack for tonight and used a fan heater in the foot well. last thing id want is the floor pan rusting out...
any one know where to get these grommets from, or the name of them, part number or if this is more universal, can i get a grommet to fit from halfords?
If the hole is at the very end, the wires are the side indicator and radio aerial, it's supposed to be there it's a drain hole (there's one the other end too, next to the battery, or should be).
There's three altogether - the primary drain for that compartment is in the middle, pointing down at the starter motor. There's a rubber non-return boot which gets blocked up with leaves etc, it's designed like it is because air in the engine bay should not get into that compartment and any holes should be sealed accordingly (including two in the bonnet structure that side of the seal).
Water coming from above the rear arches could be the rear hatch seal along the top, the rear side windows could do but i don't think it's likely.
