Wet problem...
Jumped in my 6n2 tonight after it been sitting for just over 2 hours, pulled off but when I went to dip the clutch to shift I felt a light spray of water on my leg (wearing shorts) when I went for the clutch, so I pulled over and had a quick feel under the pedal and something feels wet but have no idea where it could be from. Wondered if its ever happened before. Bearing in mind the cars just been in Arnold Clark for a thermostat problem, also had a timing belt and water pump. After they failed to find the actual problem first time. Could they be any cause?
  • Views 727
Could be failed heater matrix. Its just next to the clutch pedal.
It hasn't happened since so I'm holding my luck haha, cheers though man
