Mk 3 polo coupe front wing removal; Advice needed!
Hi I'm putting some new parts on the car as the others are a bit trashed from a knock with another car. I'm stuck on the front drivers side wing. All screws etc removed apart from three larger bolts located near the drivers side door that are covered with some sort of sealant.
I'm not sure how to go about removing the sealant to get at the bolts. Brother just came in and suggested using a blow torch (from the kitchen!).
Anyone know how to go about this??
Cheers!
Edited by Nick_593
  • Views 839
A blow torch can work, but I personally wouldn't use one in that sort of space.
Have a scrape about with an old screwdriver and you'll find them and get most of the seal off, then just soak what's left in a solvent (petrol on a rag, thinners,) to make it softer and tap a socket onto the bolt with a hammer.
no real easy way...i use a torch and a old 1/4" wood chisel to scrape at it
Cheers guys. Job done. =)
I just use a blowtorch and get it till it just drips off, never had any problems
