AEE auto trans 6N wiring diagram (engin start problem)
Hello,
I just have a problem with the starting engine, the engine can't start randomly..
when the ignition on, the engine start doesn't work, (totally quiet)
and VAG COM with no fault codes.
I've replaced the starter/key ignition switch /fuse box/ No.53 relay/
does anyone can advise where the problem is?
or someone who have the 6N wiring diagram??
  • Replies 10
  • Views 10.7k
I can help you out with the wiring diagrams but I'll need the year of the car as there are differences post/prior to Sept 1997
Thanking you so much, :-)
and my car is 1996 POLO 6N (engin type AEE with auto trans)
1.6 liter petrol enging 75KW..
Hi, Here's the diagrams for the Autobox with the starter inhibit relay J207 on diagram (53) but you will see there is an additional switch E17 for RHD cars thats mounted near the selector lever. So it might be this additional switch or the switch pack on the autobox itself this is listed on the parts list @ 52€uros !!
thank you so much..
and when I try to zoom in the PDF file, I can't see very clearly due to the resolution.
but anyway, I'll try to find out where the problem is.. :-) :-) :-)
Here's an enlarged pic of the first diagram
  • 5 weeks later...
I think the J217 (automatic gearbox control unit ,centre in plemun chamber)
and the J382 (1AV control unit(injection system),right in the plenum chamber)
they are the same parts?? :oops:
Definately two separate items
Locations of electrical/electronic components
Components in vehicle
(1) Automatic gearbox control unit -J217-
◆ Location => Page 37-7
◆ Removing => Page 37-7
◆ Checked by self-diagnosis
(2) Engine control unit
◆ Location and removing and installing =>Fig. 1
If engine or gearbox control units are renewed, the system must be brought to basic setting.
‒ Perform self-diagnosis and initiate basic setting.
=> Automatic gearbox 001 self-diagnosis; Repair group 01; Performing self-diagnosis; Initiating basic setting
(3) Throttle valve potentiometer -G69-, or accelerator position sender -G79-
◆ Further information => Fig. 2
(4)Gearbox
◆ Electrical/electronic components of the gearbox are described => from page 37-11
(5) Diagnostic connection
Location on vehicles
◆ up to ▸ 08.97 => page 37-9
◆ 09.97 ▸ 09.99=> page 37-9
◆ from 10.99 ▸ => page 37-10
(6)Kickdown switch -F8-
◆ Location, removing and installing => Fig. 3
◆ Can be checked via electrical check
=> Automatic gearbox 001 self-diagnosis; Repair group 01; Gearbox: Electrical check
◆ Not fitted in vehicles from 07.99
(7)Brake light switch -F-
◆ Location => Fig. 5
(8)Starter inhibitor relay -J207-
◆ Location => Fig.6
(9)Solenoid for selector lever lock -N110-
=> Repair group 37; Servicing gear selector lever
(10)Cruise control switch -E45-
◆ Location and removing and installing =>Fig. 4
(4)Gearbox
◆ Location => Fig.6
Thanking you for the quick response,
I found it today.. ( they are neighbors..) :-D
I think it's the problem from the connector , caused I can start the engine randomly..
I'll try to find out the root cause.. :-)
I can't see it being the connector for the gearbox control unit, I'd be looking at the switch unit on the gearbox "F 125" item # 10 in the picture, as it supplies the Earth for the starter inhibit relay.
Deffinatly look at the switches buddy, as when the car isn't in park it will not even try to turn over, where as if It was a connection problem it would surely try turn over even it was just a split second ?
I would check them an if faulty then get them off and try cleaning the contacts etc. also you could try bridging the connection, if the switch is at fault it should start up straight away.
