mk1-2-3 afh conv engine mount + plate
if your putting an AFH engine in a mk1 2 or 3 polo then ideally you need this mount and plate
it stops the front engine mount from relying on just two bolts and spread it across 4 on the block
i have machined the back of the engine mount to counteract the thickness of the plate so the engine sits in the same place.
3mm plate is now used to save removing so much material from the back of the mount (keeps strength in the mount)
The third hole in the plate has a full nut welded behind it for safety and security and the welds WILL NOT break so no problem with a loose nut
I want £36 posted for it This includes:
Machined Mount
Drilled Plate with welded nut
2 bolts with washers for bottom two holes on the block
pictures of a mount and plate i first did (will replace these with upto date pics soon)
please pm me if you have any ques or want it ;)
Edited by StinkyPete
  • Views 594
WANT.
is this sold yet?
tempted
where ou based dude?
You're tempted Matt? Has yesterday got you thinking? Lol
I have sold one so far and have another that is provisionally sold but if it falls through il let you know mate
PM'd you Pete :D
Bro, I'll get mine another time ,Sorry for messing you around, Will you make me one when i need? :)
PM me please
  • 7 months later...
I have two more of these practically ready to go so if interested PM me
