Wanted: Standard Mk3 Polo Exhaust Manifold
As title states, I'm after a standard GT exhaust manifold in 'good' condition please (obviously most of these now have surface rust, but as little corrosion as possible)
I don't think these were only fitted to GT's, but as long as it has the part number: 030129587J
Its the one that a 2 branch down pipe bolts onto...and not the single clamp type...
Thanks in advance! :-)
bump...
anyone?
Bump...
Bump... :-(
Edited by MattLoaf
  • Views 491
Pretty sure I've got a couple of these.
By the way, you are bumping far too often.
Thanks Gaz - let me know how much you want posted please.
Apologies - it moves quickly! - Didn't mean to double bump yesterday - did it on my phone (thought it hadn't posted the 1st time)
Bump...
It's a good job you bumped it this time as I couldn't find it the other day! :lol: I'll have a look at what I've got and get back to you.
Thanks Gaz, whenever you can bud...
I've got a couple spare unfortunately one has a broken stud on the downpipe but I suspect you could get this out quite easily as it has only broken at the very end so the bit sticking out could be got at with a monkey wrench. The other one looks like it has a broken stud right inside. I have a third one on an engine but that has 3 broken bolts where the warm air shroud would attach on top.
So none are perfect!
