heater dial lights are out.
don't have a user manual so could someone please post up a picture of the fuse board or just tell me the number please. think its going to be the fuse
thanks D
  • Views 729
thanks D
There is'nt a separate fuse for the heater control panel, are the rest of the backlighting working OK? Is the dimmer control on the headlight switch turned down?? Most likely the bulb has blown in the panel
Dismantling and assembling heated air and fresh air controls
1 - Controls With fresh air blower switch -E9-.
2 - Light conductor
3 - Coloured filter
4 - Fresh air regulation light bulb -L16-
5 - Cap
Pull the control panel foreward and remove the cap 5 then remove the bulb (t2.5 capless I think!)
thanks D
2 - Light conductor
3 - Coloured filter
5 - Cap
dimmer is up so must be a bulb as the only parts thats out is the heater control. thanks Pal for that.
