mk2 heater
Common problem on mk2's, the heater only works on '3'..
Does anyone know of a proper fix for this? I've heard soldering, but not what to solder..
and cant seem to find any cars breaking with functioning heaters :-(
Cheers oliver
  • Views 972
its the resistor pack thats faulty...do a search and you will find what spec part to buy and fit
yeah i know its the resistor pack but cant see to much info on what to do next.. lol
have you done the fix yourself?
edit.. just need the resistor pack, but i cant find one anywhere? not buying second hand as will most likely go when i need it.
Edited by staffordmk2
Mine's eaten several of them, i've got two left for myself but they won't last forever.
So i'll be interested in hearing about more reliable ones used from other vehicles. A lot of 3-speed units from other older vehicles are very similar and work on the same principal, just i've never got around to finding one.
Think i heard someone has used a Transit one, dunno anything more though.
Did you just get standard replacements? I could do with one soonish really with it getting cold and rainy, having
It on full wack all the time gets annoying :p
But yeah would be good to hear alternatives if there are any, or long term fixes !
Standard replacements, yeah. They look easy to refurbish as the early ones didn't have seal over them and were literally just wire wrapped around the ceramic block and soldered, but i can't be arsed with sourcing the wire sizes/types to do it if it's gonna be easier to just pull a better one out another car.
Placement is another problem. If they were in the car, like many are, then they'd probably last. But they're prone to the coating corroding because they're effectively in the open under the drip tray. Without the drip tray in place they fail in no time, so being in contact to the outside atmosphere seems to be part of the problem.
Gelling it might be the answer, then.
Does the mk3 item not work ?? :S
