Polo seat problem
Hi Guys,
Sorry but I think I put this in the wrong section first.
I`m new to the site and my son has a 1999 1.3 polo cl. The problem is with the drivers seat. The seat adjuster releases the seat but it won`t lock in position on the rail without some jiggling about on the seat. He has found that he can use the height adjustment to help lock it in. Any ideas how to fix this? Is the seat relatively straight forward to remove and repair. Any advice and guides would be greatly appreciated.
Many thanks
Phi
  • Views 793
Hi Guys,
Many thanks
Phi
Does the seat feel stiff when your moving it back and forward if it is take the seat out (10mm bolt at the front and slide all te way back should just lift out then ) and grease the rails I had a similar problem with mine hope this helps
The seat is a really simple design, just a pin on a spring which is pulled out when you lift the handle.
Do what matey says up there ^ they're super easy to get out to have a look. Remember to remove the bit of plastic runner trim before trying to get the seat out.
