Which polo to get
Hey all,
Just join up hoping to get a polo :) I already have a vw but the classic beetle kind which is in pieces. Anyway back to polos currently I have a fiesta 1.25 which at best get 40mpg for my daily, I have been looking into the 1.9D non turbo mk3 phase 2 01/02 plate to run on bio fuel as I commute a 100 miles a day and 70 of those are motorway miles thought it would be the cheapest. Also another reason I am looking at polo is that they are small cars and my partner has recently passed so a small car is ideal.
I know running bio fuel you need to change the fuel filter, any suggests or input would be great.
Thank you in advance matt.
  • Views 771
The phase one 6n1 had the non turbo 1.9 but i thought the 6n2 only got the 1.4TDi which qualifies for cheaper tax. Better engine too, quicker and uses less fuel.
there was an SDI mike just not very many were sold as the TDI was better however for running on fat or biofuel the SDI is much better. though if you do long distance my 1.4 16v polo did 54mpg on a run (which coincidently is the figure provided by vw) is way quicker and more fun than a 1.25 fiesta. you can run it on ethanol if you modify it to take ethanol.
From Banbury? Did i see you say your beetles in pieces? Mind if I ask where (which garage/bodyshop?)
TBH, I'm not so convinced on the biofuel thing. It's not as cheap as it was, unless you have the means to buy it in bulk. Have you looked at the mpg of modern diesels? On the kind of run your doing there, in my 1.4tdi I'd be getting close to 550 on £60ish driving at the speed limit
Thank you very much for the input guys :). Only only issue i have with the turbo is it may not like the bio-fuel also it means less maintenance not really after that etc poke, just a old diesel to soak up miles.
Well i seen bio fuel at 90p so that is why i went with it. Also my budget is about £1000 so early 51' or 52' plate. And the beetle body is getting welded in a garage in Warmington. Thank you again all for all your help
