breadvan roof size
bit random but can someone tell m approx size of breadvan roof gutter to gutter for the width and windscreen rubber to back of roof .preferably in inches and also load space length from front of back seat(ie were it drops into rear footwell up to the back panel please.also does rear wheel arch protrude into car same size as the coupe does / thanks
Edited by vw1970
  • Views 882
I'll measure up for you tommorrow if I remember (I put this caveat on everything I plan to do as I am prone to forgetting everything).
Width of the roof will be the same as your Coupe S.
Arch intrusion will be the same as your Coupe S
The wheelbase is the same, but they're about an inch or two longer behind the wheels than a Coupe. All the same in front though.
cheers for info .just need length of roof then (just the flatish part as I'm trying to source a small pop top for my 2nd attempt at polo camper.dont pick breadvan up till 15th. thanks :-)
Didn't quite know where to stop measuring, so I laid the tape from the end of the roof, to the windscreen rubber at the side of the roof and that was 64". The front of the roof will be the same as your coupe S, so just take off however much of your roof you wouldn't use.
lovely thanks.
