Mk2 Scirocco Scala Breaking
Hey guys got a mk2 scirocco for BREAKING. Car is road worthy has 9 months MOT but I built a new 1.9 8v engine for it but it has blown blue smoke since the build. I was supplied with the wrong oil and I am lead to believe the bores have polished, Past compression test at 190psi on all four cylinders. Anyways I have lost the love for the car now because of this foolish mistake. Have got the whole car minus the clocks, o/s/f door, o/s/f wing due to these parts being faulty in some way. Things that are of value:
Recent new fuel tank and filler neck may have some surface rust £40
Budget coilovers and febi top mounts and red poly rear mounts near new £100
Bottom arms with red poly bushes near new £20
Astra GSI front brake setup with goodridge hoses, new pads and discs may have some surface rust due to lack of use £30
Complete strut brace set could do with a coat of paint to make them mint £40
Rear axle been modded to run 3 degrees negative camber, camber shims to correct the toe in, fitted with near new drums, bearings, shoes, wheel cylinder, cables, springs kit, goodridge hoses, red poly bushes and was all painted when assembled £45
Down pipe back stainless exhaust with a stainless 2.25" 45degree upswept pipe welded on £40
Scala seats with small amount of wear will have pics to follow £65
1.8 8v engine rebored to 1.9 using pistons, rods and crank from a 40,000mile TSR engine. Fitted new shells, seals, rings, conrod bolts, tappets, oil pump, windage tray, Febi sump with belt and braces baffles welded in, TSR metal head gasket, recondition standard TSR head with TSR donnington Cam, new timing belt and water pump, LUK clutch, new rad, thermo stat. Got a few reciepts to prove the work. Like I said above eninge smokes, mainly when warm and turning right lol sad.gif , I changed the oil to run in oil after one day of use with fully symthetic. Its only done 700miles since being built but I am willing to break. Would take £250 for complete engine and box or £500 for the whole car. Just need this gone guys.
!!!!!WILL HAVE PICS TO FOLLOW BY TOMOZ!!!!!
Located south wales, aberdare, cf44
Contact me on 07983801662 or PM Me
  • Views 510
how much for the braided brake hoses?
would need them posting to Nottingham BTW.
oh and the short length of hose from the filler
neck to the tank, and the hose clips.
cheers.
only the rear hoses will fit a standard application as the fronts are off a 6n polo as I was running the gsi front caliper conversion. Thanks
Pictures of whole car please
Any pics of exhaust system and seats
