Mk 3 polo coupe catalyst badge removal?
Hi how do you go about removing the 'catalyst' badge on the tailgate of a MK 3 polo coupe?
  • Views 987
i used hot water and some dental floss :) be careful not to pull the paint off though ;) just give it a good going over to get the foam off, i think someone will tell u the best product to use, i cant remember sorry :lol:
A heat gun will soften the adhesive, you should then be able to ease it away from the metal. A hair dryer may even do the trick, but I have never tried it.
Regards.
  • 1 year later...
I was planning on doing the same to my car. I was wondering, is there holes in the tailgate underneath or is it just held on with adhesive?
Held on with adhesive
Just poor hot water behind it let it soak for a bit then slide a credit card behind it to pry it off. Then use a toffee wheel to remove the glue. If you don't have a toffee wheel you can use lighter fluid and a cloth to rub it off. And when I did mine I went over it with some T-cut to finish it off.
