clearing headlights
anyone in the south west cleared the yellow fade on their headlights by sanding them? really want mine done but haven't got the balls to attempt it! was wondering if anyone would do it, ill pay :)
  • Views 891
Dishwasher!
Really? dishwasher or are you kidding?
I've sanded mine lots of times but it always come back.
and it will always come back no matter. they come from with protection on them so sanding them has removed the protection. you can buy clear films for them but there quite cos\tyl but cheaper than new headlights.
If u buy a good cleaning kit, turtle wax for example they give you an additional rag soaked with the syuff u need in order to protect them.
what car do you drive? I'm from plymouth will keep an eye out.
The key is in the sanding, start off with 600 dry, then wet, then 800,1000,1200,1500 should do it but you can go finer if you want, then polish it. I used g3 compound on a wet rag then worked the whole thin over thoroughly, this should get them clear. As for protection you can use turtle wax etc or, my personal favourite is clear laqure, some people will be against this but I have done this many times with good results. But if you haven't done it before then I would say use a wax.
Also when sanding, go top to bottom from left to right, then again from left to right top to bottom, of that makes any sense? Ie go in all directions with each grade of paper.
HTH
