Ignition barrel change
Hi all,
My brother in law is trading in his 6n and they are just going to scrap it so I'm going to swap over all the good bits to mine, one thing is the lock set, the doors and boot aren't a problem but the ignition is a bit more complicated.
So what I am asking is how can I get the lock off with out damaging it? Bearing in mind that they use different key types, is it possible to change over just the barrels?
OR
is it easier to just swap over the whole steering collumn? And if so do these differ between power steering and none power steering setups?
Hope this makes sense?
  • Views 1.4k
You can swop the barrels over, for ease you'd need to remove the whole steering lock assembly from the column by drilling out the shear bolts and then drilling a 3mm hole in the lock assembly to remove the barrel There are differances between the early and later lock assembly, the later one has the immobiliser read coil built into it and is'nt replaceable where as the early one the read coil is seperate. As far as I can see there is'nt any differance with the column with or without PAS
So it would be a lot easier to change over the whole collumn? Is here a flexi joint inside ? Or is it held on from the rack? Probably a silly question, but the car isn't near ATM to check.
And also, will the immobiliser part just swap over? Or would you need to swap over the whole immobiliser setup? On mine I have disabled the immobiliser and I use the one on my alarm but on his one It is factory.
Thanks for the help
you can drill the 3mm hole in place aslong as you remove the cowls
Hi,
Thanks for the reply.
Didn't end up doing it in the end as I didn't have enough time and the car has long gone now. Hopefully this can help someone else searching for it years from now...
