losing rear seats....
As my rear seats are effectively redundant at the moment I figure why not just take them out and put a false base in....few questions about this...
I'm assuming a good this layer of mdf for the job?
Also, has anybody else done this in a 6n2, if so how was best to match the contours of the shell...several bits all "pieced together" in eithe? Or making up a template and wiggling it all in in one?
Interested to hear thoughts from people who have done this sort of thing before, cheers!
  • Views 979
I've done it a few times in mk2f .one piece using cardboard tmplates i found was neatest loooking way
I always have a separate piece above the spare wheel to get to it easier.
If you're not mounting speakers to it, you're better off with plywood, it weighs a fair bit less than MDF.
Make a cardboard template (start by drawing round your boot carpet), then jigsaw it out of one sheet of board.
Don't forget it'll need some support over your back seat base well, and you might to get your spare wheel out one day!
Ah the spinal guillotine, always wanted a ride in one of those just for the danger buzz.
Wheelchairs are quality these days, you get plenty of time to think about space and the universe and the meaning of life and stuff, between charges.
No. One big sheet of wood between your back bumper and your spine is not a good idea.
Cheers guys, cardboard template seems like a good shout....ill just pretend I didn't read that last post -.-
i have flocked dash and door cards are there a bit of an arse to clean. have to use tape turned inside out to pick up the crap
just a warning
Fair point, probably better to do it in two peices and just use the carpet or some light battens to keep it together.
