6n2 Gearbox/Pedal box issues. How common etc.?
Hi
I currently own a 1.0 mk3 coupe, but as i am now doing more miles my parents would like me to get something a bit safer. I have about £1200 to spend, and I'm looking at 1.0 6n2s with between 70-90k miles on them.
I was just wanting people's opinions on them, mainly regarding the issues relating to the gearbox and pedal boxes these cars supposedly go through. Is it really as common as it seems? Does milage have an affect or is it just pot luck? (heard of some going at 50k) How expensive is it to fix?
Thanks for the help
Will
  • Views 699
They did a recall on the GTi's, so pretty common tbf. How handy are you with a set of spanners?
This was one of the first jobs I did on mine, didn't take that long (and actually welded the old one back together, instead of replacing). That was two years ago, still solid!
Yeah i heard they had done a recall. Was it only on the Gtis?
I'm fine with a set of spanners and my dad isnt bad with a welder so it should be fine.
Was the recall on the gearbox or is it just a case of getting a new one when it goes?
I had a low mileage 6n2 1.4 and the peddle box went, on nearly all gti's it appears to have been a big flaw. Put me of buying another 6n2.
If you get stuck in, you can do it in a few hours. You've got to remove the steering column to get it out mind, not hard though. Even try and pick one up with that problem, and do it yourself!
Save yourself a few bucks and learn about them, they're easy as hell to take to bits!
