Help! name the part
Hi guys, I'm new here and i have just brought a polo mk3 GT, i got it not working under the assumption that it had a duff battery and a starter motor that needed a refurb. the car needs a service but as i was inspecting it i found a part on the car that is snapped in half. it looks like a giant resistor. i would be grateful for any input. also the car was sitting for 2 years what else do you think i need to do to it?
Sham 8-)
Some pics
http://www.flickr.com/photos/88638316@N02/.../in/photostream
Will add the pic of the brocken part in the morning
Edited by dmacz220
  • Replies 28
  • Views 1.9k
Picture(s) of the broken part? Where was the part?
thanks for fast reply, will add pics of the part in the morning, it is situated under the bonnet on the passenger side. it is attached to the arch wall and has 2 yellow wires coming off it. its some kind of coil.
Sounds like the ignition coil.
It is the dim/dip resistor for the headlights ;)
X2 is it cylindrical? If the wires are yellow then I would say its the domain resistor. Just unplug it, that way it's out of the equatio, all it does is put the dipped beam lights on at half power with the sidelights.
still dishing out the expert advice then
Lol you tit. Since when has your ignition coil had 2 yellow wires on it ffs! It needs a big black ht lead on it for a start!
Its the dim/dip thing as has been said.
Ok, thanks guys for all the posts and your help, I'm still not too sure what this thing is, so as promised but delayed, the pics.
http://www.flickr.com/photos/88638316@N02/8090213641/
Btw this is a great forum, I think I'll do we'll here, paying for membership today aswell :-o
defo dim dip resistor...makes the headlamps glow when side lights and ign is on
some of us only respond if we know the answer
Ye, dim dip resistor. All it does is bring the dip beam up to half power to boost the light output when the when the switch is on sidelights and the engine running.
It was only fitted to the UK spec cars for some strange reason, especially when certain EU countries at the time were forcing manufacturers to build cars where the lights came on automatically with the ignition, Volvo and Saab being the best example.
TBH, most people unplug it and forget it exists especially when they have LED sidelights fitted so its not a biggie.
If your paying today then your membership pack should also be with you by next week. :)
Early mk2's dont come with them :p
Ignition coil fucking hell hahaha
Thanks guys, now I know what it is, you guys are extremely helpful. I have another question however, the car has just had a new battery fitted, and it will only start once every 10 turns of the key or so, is this a solenoid problem?
You mean it'll over crank after like 10 turns of the key?
Vague description = inaccurate answer and I was hardly going to go raking around my engine bay at 1:45am. FYI not everyone knows every square inch of an engine bay off the top of their head, unbelievable I know :roll:
starter motor
starter motor
haha made me chuckle
If only there was a like button on this site half these posts would have just been liked! :p
Edited by Monkey-man
starter motor
If the starter motor is turning the engine and engaging, doesn't that mean that it's functioning normally?
How are you guys so stupid...its OBVIOUSLY the sump.
duh.
He was taking the piss with the starter motor comment dude!
Quantum capacitor for the transisting diode relay is what it is!
Your all goons for not figuring that one out!
Do you mean this relay (pic) because when the ignition is on it makes an almighty buzzing sound?
http://m.flickr.com/#/photos/88638316@N02/...in/photostream/
Buzzing sound in a MK2 when the ignition is on? That's most likely the front speaker..
Hi guys, I can now rule out everything else mentioned, it was a dodgy fuel pump relay next to the Ecu
Fuel pump wasn't priming when ignition was switched on. Replaced the relay now everything works ok
Sham out
Windscreen wiper stalk sounds faulty....
