New to Polo's :-)
Hey girls and guys! I'm new to owning a polo and must say its the best car out of 14 I've ever owned. Reliability along with nippiness and great MPG.
I am however, confused on a few bits.
6n / 9n etc? What's all this mean?
What do the engine codes mean? ABD etc.
What am I able to do to my car?
What is my car? 6n? What engine code?
I have a 1.4 8v 1997 VW Polo.
What engines would sit into it?
I'm just out to get the basics and any help from you polo gurus would be of great help.
Many thanks
Jack
  • Views 1.3k
Basically it's all just a big time line haha.
6n2 is a facelift version of the 6n.
I would explain with pictures but I'm on my phone!
'6n' and '9n' are the chassis codes of each model
Engine codes are just VW's way of naming each different engine. (you can find tables that explain engine codes and gearbox codes)
for example, my engine code is AAU. it's the 1043cc 'SPI' unit found in the mk2f. The 'AAV' is the 1296cc SPI unit, and the 'NZ' is the 1296cc MPI unit.
You are able to do lots of things to your car. The by far most common thing to do is to buy coilovers, and have it low, ~But this isn't to everyone's taste.
Your car is what VW refer to as the Mk3, because it is the third generation chassis. Club Polo will call it the mk4 because after years of calling the mk2f the mk3, and the mk3 the mk4, it is impossible to revert this. The chassis code is 6n, which is now what most people call them because you cannot argue this! Your engine code is 'ABD'
Welcome along :)
Mike's summarized the body marking pretty well. It is quite simple really. But for anyone still confused, i think this is a fair explanation..
Bodies!
Take this shape for example..
It's the third generation body, so it's a MK3. The chassis code is 6n. If it was the facelifted 6n then it'd be the 6n2 aka MK3F. Facelift is largely cosmetic and minor technical revisions, a revamped model. But still basically the same bodyshell otherwise. You'll find this info on Wiki due to it being so popular. And it's how my VW dealers and parts suppliers see it.
Clubpolo have done it differently. The club has had a culture of giving each shape a new mark since it was a small group of people a decade ago when most of the cars were pre-'94, so they created the 123 pattern you find later replicated on the site Polo3. This made sense in it's own way but then spiralled out of control as new models were introduced, and we're currently at what, MK8? I loose count..
So regardless of the sense VW and the rest of the world are making with the body-type version (have a look at various european sites), after a short trial to change the CP version overnight, there's some preference now by many to keep this one going as well.
Simple answer then is to just use the chassis code, because it's stamped into the body (6n in this case), and it's on the registration document, so that can't be re-invented by anyone. Or you'd think. Not entirely simple for those of us with any form of MK2 because the chassis code for all MK2's is 86c. So there's an 86c and an 86c facelift. This facelift car is the MK2F of '90-94. All this probably helped lead to CP's secondary grading. Wiki are keen to point out that this is sometimes used in error.
The 86c
This last issue is even further reflected when you realize there are three fully different MK2's - because the original MK2 of '81 had a major revision in 1986 and almost no part went unaffected. Engines were redesigned, suspension, electrics, trim, even some panels.. From the door handles to the pedals, it all changed here, turning the it from a re-bodied MK1 to virtually a new car. But it was all kinda hidden and the early and late cars looked the same and are not recognized by different identifications. On reflection, the facelifted car in 1990 was pretty much all cosmetic apart from engine management, carrying over most of the late MK2 technically. So a 1989 MK2 is as much like a 1991 MK2F as it is a 1982 MK2.
I hope there's nothing pedantic about explaining all this, i know it isn't popular information but the question was asked, and though i've gone into detail on the 86c there's no use explaining half a picture at the main point of confusion..
Engines! Gearboxes!
Codes used to be shorter in the '70s and '80s. Not just body but a typical engine was two letters (the 1988 1.3 55bhp engine was MH for example). But engine codes changed to three letters in the early '90s due to the quantity of different engines. Gearboxes also have such identification codes, and again, were two letters and went onto three along with engines. So this 1.3 engine was sometimes specified with the 8P gearbox.
This makes for an 86c with MH engine and 8p gearbox. That is, in the form of my old '88 Coupe-S.
A 1998 Polo would be a 6n and could have an AFH engine with a DXJ gearbox. This would be a late pre-facelift 16v model.
Then 6n2.
Then 9n
Then 9n3 (i'm not knowledgable to comment on the phantom 9n2 gap)
Then 6r which is the current model.
And Mike's expanded on the body marking pretty well!
The 9n2 was a 9n Polo saloon which is not available in the UK. From what I read that is.
(I love being a nerd 8-) )
As mikethebike says it appears that the 9n2 is a saloon version of what we call the 9n (picture). There is also a 9n4 which I assume is a saloon version of what we call the 9n3 (picture). There is also a saloon variant of the current Polo called the Volkswagen Vento "A sedan version of the Polo Mark V was launched in India and Russia in 2010 as the Volkswagen Vento and Polo Sedan" (Wikipedia). I read somewhere that in other parts of the world saloons are more of a status symbol more than anything else.
Wow! You guys are by far the most intelligent car enthusiats I've ever had replies from! Now I'm more in touch with what car I acctualy have I will be able to move forthwith and modify my POLO. Thank you so much guys. This thread should be stickied after the full detail that's here haha
