valve clearance from gt head on a abd bottom?
as title, does anyone know what the valve clearance will be with a gt head on a 1.4 abd bottom end, i'm looking into a cam.
  • Views 574
You will be able to get away with a 272 before thinking about valve to piston clearance.
Remember some cams list lift with the valve 1mm off the seat, others list from seat.
So you cant run a 272 in most GTs without machining pistons...but you can in ABD?
Nah you can a GT & ABD
