Removing and Replacing Roof Rubber Trims
Hi
Just looking for some guidance, I'm in the process of wrapping my roof with carbon fibre vinyl and thought of removing the rubber trims for a better finish and while I'm at it to give it a good clean, I will then put them back on
Does anyone know of any DIY Guide on how to remove these and once removed can they be easily put back in place
any information will be highly appreciated
  • Views 965
Sorry forgot to mention, it is a five door 6n
I took them off my MK3 coupe, Worse decision ever, Sticky/laquery stuff was holding them on, I've peeled most off just gonna start to rust, So i need new ones ASAP!
on my m3 polo they where held on my mastic, not easy to get off without breaking
Thanks guys
Anyone else with some experience trying this on an MK4
On the 6n they are held on with metal binding inside the rubber, easy to get off. But you must be gentle when removing and try not to bend it as it will hold its shape. I start at the front where the windscreen meets it. Flat head driver under it and lever it up. Then run the driver along the roof under the seal to lever the whole thing. Use your other hand only to hold it do not pull it upwards or it will bend. After cleaning it all up go along the seam that holds it on with some pliers to crimp it so it will hold on better. Some grease or oil along the roof seam will make it easier next time and may prevent rust.
HTH
Cheers mate.. that's helpful :thumbsup:
