085 box even if broken
I'm after the reverse gears out of a 085 box think it's got to be a box off a 16 v . So if any one has a broken box except reverse lol cheep as possible plz
  • Replies 9
  • Views 589
Got a 4 speed you can have for £20 in sheffield
Not shure if the gears will be the same size off a 4 speed iyl have a look into it .
I stripped an '88 4 speed gearbox early on this year and the reverse gear was the same as the one on box I was rebuilding which was an 8p (5 speed). I also have a spare reverse gear, the other half of the reverse gear is part of one of the synchro mechanism.
Iyl add a pic when I get chance if you think they are the same I'd be interested !
I also need the idler gear
I have the set - edited to add pictures. Drop me a PM if you want them..
Edited by Vic
Still in need anyone ?
It's the one on the right I need the inside teeth are slightly different .
All sorted now .
