6n2 interior
Hi guys. Looking to wrap my pillars and dye my headliner. I'm ok at removing the headliner but I'm curious as to how the pillars come off. From guess I would say the a pillar just clips off and the c pillar looks like i need ti remove the plastic trims in the boot. but the b pillar is the tricky one. Any help?
Car is a 3 door 6n2
  • Views 3.4k
Removing and installing A-pillar trim
1 - Seal
q After installing trims, ensure seal is seated correctly.
2 - Trim panel
q Removing:
– Pull off trim and unhook retaining lug → Item.
q Installing:
– Check seating and condition of clips → Item and correct if necessary.
– Hook retaining lug → Item in first.
3 - Clip
4 - Retaining lug
Two-door Polo B-pillar trim
1 - Clip
q Qty. 5.
q Removing:
– Turn clip 90° and pull out of B-pillar mounting.
2 - Trim panel
q Removing:
– Loosen door seal → Item in area of B-pillar.
– Release retaining lugs and swing cover → Item upwards.
– Remove bolt → Item.
– Remove guide fitting → Item.
– Unclip trim from B-pillar, beginning on door side.
q Installing:
– Check function of belt height adjustment.
3 - Door seal
4 - Cover
5 - Hexagon head bolt
q 7/16 x 20
q 40 Nm
6 - Belt anchor
Two-door Polo C-pillar trim
1 - Clip
q Qty. 3
q Removing:
– Turn clip 90° and pull out of C-pillar mounting.
2 - Trim panel
q Removing:
– Remove support for right luggage compartment cover → Chapter.
– Remove support for left luggage compartment cover 10.99 ► → Chapter.
– Release retaining lugs → Item and unclip cover → Item upwards.
– Unscrew belt guide → Item.
– Unscrew spring clips → Item.
– Unclip trim from C-pillar.
q Installing:
3 - Spacer sleeve
4 - Spring washer
5 - Belt anchor
6 - Hexagon head bolt
q 7/16 x 20
q 40 Nm
7 - Cover
8 - Locking lug
9 - Spring clip
10 - Seal
Removing and installing support for right luggage compartment cover
1 - Support
q Removing:
– Take out luggage compartment cover.
– Remove Torx bolts → Item.
– Unclip support from C-pillar trim.
2 - Retaining pocket for two-door Polo
3 - Retaining pocket for four-door Polo
4 - Torx bolt -T20-
q 1.5 Nm
Removing Left side support
WARNING
Disconnect battery earth strap before working on electrical system.
– Remove bolts -1- and -2- and remove support.
– Unclip luggage compartment illumination -3-.
– Disconnect connector -4- from socket -5-.
Fooking fantastic mate! Thank you!
No problem :-)
