Need some guidence?!?!?
Right I want to get a retro roof rack for my matt black Breadvan.
I was woundering what would be the best to buy for looks that would fit, Dont want to pay ridiculous prices though.
Any suggestions?
  • Replies 9
  • Views 912
It has the traditional universal roof guttering, so pretty much any old skool rack will fit.
Personal preference then, i have a black metal '80's style one, it suits the car but is only used if i need to use it, such as carrying the canoe - can be a bit embarrassing otherwise because to some people these days it looks like it's on there to look scene..
Best way around it would be to fit the factory roof bars. You need a post-'85 car and the brackets/reinforcement plates from the donor car. And a rivet gun.
I don't see why you need a riviet gun for the factory rails? I fitted some to my '94 bready? just drill some holes and bang 'em on. Unless your speaking of something different.
desmo are probably the most readily availible. but if youre not actually using it it just looks stupid, and when i had one on for the bike rack i noticed the wind noise and it really struggled on the motorway
I have some roof bars you could convert into a roofrack :grin: Yours for a tenner!
The front mounts of the rails, at the b-pillars, use reinforcement plates. When the bars are sold seperately as used items they don't usually include these, which is a bit of a fail. I took the time to remove them from the donor car when i sold a pair of bars, you need a rivet gun to fix the reinforcement plates to the new car's shell (VW used rivets to fix them originally).
Sounds like you don't have them, and your bars are not as strong as a result. Unlucky.
Beneath the roof skin is a insert which the bolt sits in, this is all I presumed was needed for support, been as there isn't any weight transfered to the roofskin .
Theres really no need for sarcasm. I was just stupid enough to question something you said.
Oh well, I did it for asthetics anyhow. But i could comfortably say there'd take the weight of anything I'd what to put on my roof.
Edited by MaxVW
More like i was stupid enough to answer - so what you didn't do your research before carrying out a modification, good job it wasn't someone elses car, but you don't need to cry about it with some attack on my attitude. I don't even see any sarcasm.
The plates aren't exactly thick, i'm sure it's strong enough, but they are there for a reason. There is no weight on the roof skin, the plates are riveted to the frame under the roof skin, which takes all the weight.
I was just giving out proper advice if that's okay. My posts shouldn't get in your way again.
?? I don't really see why you're getting so defensive? I'm not here to argue just to learn and talk about Polo's.
More scarcasm, YIPPY!
From what I have read from your posts, you are very knowledgable. I'm just unsure why you didn't like it when I questioned something you said. Won't happen again.
My sincere apologies.
Max
I'm not going further, it's all above. It's easy to get wires crossed in text, clearly happened here, no worries.
