Water getting in boot!
I noticed last night that a bit of water was running down the N/S side of the boot, on the flat bit of metal where the seat belt is mounted. Unfortunatly for me, my battery sits in this corner!
Any Idea where it's sneaking in from? I thought if its a common problem somebody might be albe to me exactly where too look, otherwise I'll have get my investigation skill out!
Thanks in advance =)
  • Views 733
I had some water coming into the boot of my 1993 Polo Boulevard, and we discovered it was coming in through the seal of the rear lights.
We siliconed around the light box and no water since!
ads x
Turnt out to be coming in though my ariel, running down the lining then into sight! Went to tighten it but it turnt out the thread was stripped on the ariel!
Got a replacement from a fiat stilo in the scrappy, but the connections are different! As long as its not leaking its ok tho.
Anybody no if a 6n has the same connector as a G40?
