seat ibiza cupra mk3 seats into a 6N problems....
Basically I bought these seats thinking they'd fit straight into my 6N, I read up and seen that the mk3 seats were the only non straight fit in and needed abit of modding. I've got these seats here and how the backs secure themselfs down is different. The polo seats hook in and the ibiza seats bolt in. I also don't see how I could swap the backings round as the seat bottom half is 2 piece and the polos 1. Any replys quick would be AMAZING as I'm trying to fit them right now! Thanks alex!!
  • Views 2.8k
This is the Ibiza rear seat base, pull the wire out of the mounting plate and it should then clip into the hooks on the Polo floor, and if your removing a single piece rear seat you'll need the centre fitting bracket for the divided rear
It bolts into the holes already in the floor pan
Cheers again mate! Ah the bolt holes arnt in the floor pan on my 6N! :(
That's strange :? as mine is a poverty spec with the single piece rear seats, but the holes were there when I fitted the split rears from a 16v
Naa I mean to the rear bench bases to bolt to, them holes ant their
As I said pull the wire out of the Ibiza mounting plate and it should then clip onto the hooks on the Polo floor
Alternatively drill the seat rail and nut n bolt the Ibiza mounts into position
