From Polo to Lupo
Hi every one. As you may already know i have had polos from the age of 17 :) from 1.0l up to the 1.4 afh. the time came where i fanced a lupo so still vag but not a polo. any way here she is a little differant to the normal euro look but still slick .
spec
1.4 sport
Full engine rebuild with every bearing, seal and many bolts replaced with genuine VW parts
New Genuine VW oil pump
New Genuine VW valve stem seals and valves
Head skimmed to raise the compression ratio
3 angle cut valve seats
Ported and polished
Schrick fast road/race cams (no longer produced)
Bottom end balanced
Block painted black with head painted red (gti spec)
GTI Radiator
Full gearbox rebuild with uprated/strengthened bearings
Brake callipers painted black
Front bumper smoothed for a more evil look
Tinted indicators and headlights
Freshly powder coated compomotive mo5's 15x7 et35
195/50 parada spec 2's done like 200 miles
Ap coilovers still height adjustable and not seized
24mm Rear one-off anti roll bar only one in the country (supposedly)
Front gti roll bar
Front is polybushed also
4-2-1 manifold into a custom stainless de cat exhaust
Tarox F2000 disc and green stuff pads up front (200 miles old)
Bmc CDA
Full interior strip with bride bucket seat and willians harness
Omp deep dish steering wheel with carbon gti horn push
Oil pressure gauge located in drivers air vent
Chequered roof lining with gear gaiter to match
Hertz component speakers
LED interior light and number plate lights
  • Views 3k
Now thats a bad arse lupo pal
  • 4 months later...
with that steering wheel can you hit the indicator stalk without taking your hand off?
