1.0 Litre Polo 6n2 Fuel Burns Fast
Hi, My problem is that i will fill up a tank and only get like 150 miles out of it, i used to get 400. I drive normal no over revs etc and also sounds like the engine is running fast when idling but revs still remain under 1000. Any thoughts ? :)
Thanks,
Ben
  • Views 674
Have you checked that: 1) The brakes are not binding? 2) That the clutch is not slipping? 3) That it isn't overdue for a service (new spark plugs)?
Regards.
Regards.
Cheers for the reply do you think i should just get it checked over at a garage ?
Service and check all sensors .. Eg throttl pos and Colant temp.,,
Dodgy coolent temp sender can cause the car to run as if its cold I.e as if it was running with a choke on. overfueling etc and revving high
Ok Cheers, I'm going to service it myself today then check all that thanks alot :)
