6n2 gti
just bought myself a 6n2 gti...now every telling me have fun changing gearboxes all time etc, iv looked on here and no one seems to have that many problems, is it really as bad as they say or just something that happens if you miss treat it like any other gearbox? its an X reg btw dont know if anyone could clear up what there saying to me and what to watch out for? :) cheers
  • Replies 10
  • Views 979
mine was fine up still 80,000 miles then went bang but I have Heard they can be bad I think it's the bearings and the diff that goes but I'm not 100% sure
My mom had one for a year or two, they were newer then, but she had no problems with it. I think it's just like any other car if you thrash it it's going to break.
The traction control puts pressure on it that it wasn't designed to handle. Not that wheel-spinning is kind on them, but at least that's an energy escape, whereas TC holds it in the gearbox..
The gear oil is probably thirteen years old, you at least wanna change that.
my polo hasn't got traction control I dint think they come with it
Not all of them had it.
i know the car from the past 2 pervious owners who changed the gearbox oil on a yearly basis if not more regular and the car was serviced every 3months! how much a gearbox if it goes?
I sold a good used one recently for about £160 (can't remember exactly, bay job). Recon expect circa £600.
got mine done in a place in dartford it was about £500 with old gearbox and free fitting and there show you what was wrong with you are old gearbox I found them on eBay
http://item.mobileweb.ebay.co.uk/viewitem?...nid=59882585021
this is what they say on eBay about the gearbox
Symptoms: –
Gearbox leaking oil either slowly or pouring out, sometimes with slipping clutch due to oil
contamination. Often the gearbox jams and the car can not be moved. Gears fail and there is no
drive to clutch and wheels
Cause:
Hole punctured in the gearbox casing due to a sheared weak rivet on the differential failing.
The rivets attaching the final drive gear to the differential are weak and shear off, sometimes
after only 30,000 miles on early gearboxes. This a common problem with these gearboxes.
Cure:
We Replace weak rivets with stainless steel nuts and bolts, add reinforcing metal plate
between the bolts (where applicable)and then fully rebuild gearbox
They're talking about differential failure, which is one particular failure - a catastrophic one at that which smashes the gearbox up and can cause an accident. The diffs were reinforced at some point, i don't know when from but i thought it was the traction-equipped models. There's a kit available from VW to reinforce the diff before it smashes itself to bits - this fits all bolted crownwheel 085 units.
Other more common faults include various bearing wear, and syncromesh wear (particularly on 5th due to it's sloppy rose-jointed linkage, though this is easily adjusted - details in the FAQ).
