ad's 2011 Polo 6R... HU, Lights, Lowered,Wheels
Finally made a decision and got my new wheels, fitted them today to check nothing rubs or catches ...
Also fitted SEL grille ...
  • Replies 31
  • Views 8.4k
Well to cut a long story short ,this is the first time I've messed about fitting wheels that haven't been a direct fit on a car and to be honest it's been a learning curve for sure , I've had to make adjustments to all 40 bolts to make everything fit right just when I thought I was sorted I've had issues with the tyre size (on reflection it's so obvious now!) But once fitted I found that the TC was cutting in constantly due to the 185's on the front and 205's on the rear so I've changed the fronts to 205's and problem solved. Took it for 4 wheel laser alignment today so it's all good .Also swapped the centre caps for black and silver ones
hi mate, car looks well on the new wheels!
What size are they may i ask?
Thanks mate, they are 17's
sweet, do you know the widths?
Cars looking great man! What side lights and number plate light did you get? simple things, but make the car look great at night :smile:
Thanks for the comments mate, the sides and where off eBay the sides are 6 led ones and I think the number plate lights are 32 led in each holder
