6n2 speaker pod picture request
All right I'm going to making some door pods for 6.5" speakers but I'd like to see what other people have come up with to help me deside how to go about doing them
Id like to trim them also but the arm rest doesn't come off so that's stopping me trimming in 2peice pattern not sure how to go about that either
Show me what you have :)
Any help/tips would also be great
  • Views 811
The front doors already have 6.5" speaker holes?
Yes there are but my plan is to point them up slightly and angle them towards the seats
Ah right, understood,
Have you though of getting mdf speaker rings cut (eBay speaker rings) and using wooden dowel rodsad gluing the ring to the stock plastic ring, this them brings the speaker out from the original hole, you can then cut the dowels to lengther so they poin where you want. Then when it's all finished, cover it with material and coat it with resin then use some fibreglass mating to strengthen it from the inside.
You could even close off the backs of the original speaker pods to create an enclosure?
Yes that's exactly how I was going to do it routing some mdf for flush mounting but can't do them till I've decided what bass drivers to get, also i just wanted pictures of what people have done, it's just the trimming that I'm not sure about because I don't want the full card one colour or meterial but the card doesn't split so I don't know how to do that
The card should split, like for instance or the gti and leather interior but you may have to split the backing material along the perforated lines and then cut vinyl trim to get it apart if yours is the black or grey standard interior, the door pockets also split away from the panel.
As for pictures hopefully someone else has done this and can help out?
