Car respray: paint code conformation.
Hi car is going in for a respray tomorrow and I'm using the code from the forum. The car is 'Calypso green' and I want it in the same colour, however under the paint codes link it only has Calypso.
Last minute conformation as I dont want it to come out wrong!.
Am I right in saying their the same?
  • Views 1.2k
paint code should be on a label in the boot open boot stick your head inside and look back at your knees on the inside of that rear panel
if its going into a bodyshop then they will know what paint code it is, if they don't then i would take car elsewhere
Cheers for replies. Took it in a week ago for some body work, he knew VW's had the code in the boot but he didn't see it when I was with him. Paint going on tomorrow so just wanted to make sure.
Passed on where the label is so should be sorted.
There will be a copy of the sticker in your service book too if you have that.
That's very judgemental.
I've painted cars before where the colour codes not known and only got a name to go with, that's why you do spray out cards and check it to the car.
I've even painted cars where the code and name aren't known because its a classic car and I had to get a paint rep out to scan the car and come up with the closest colour. I've painted a Stag a Mazda colour and a Mk2 Corina a Fiat colour for example.
You can always find a code, colour and name, saying take it somewhere else isn't right.
