Alter the clock 9n3
hi all I've look and fiddled with loads of dails/switches on the car but how on earth do i change the time
VW Polo 2006 9n3
cheers!
  • Views 7k
Clock: Set to correct time
Carry out adjustment as follows:
Setting hours:
– Turn setting knob -1- (on lower left next to speedometer) anti-clockwise.
By turning the setting knob shortly, the clock will be altered by one hour. By turning and holding the setting knob the alteration will be continuous.
Setting minutes:
– Turn setting knob -1- clockwise.
By turning the setting knob shortly, the clock will be altered by one minute. By turning and holding the setting knob the alteration will be continuous.
With the setting knob -1- the clock can be set exactly to the second as follows:
– Turn setting knob to right until the time is one minute before time to be set.
– Turn adjustment knob to the right at the moment when the seconds indicator of accurate clock shows a full minute
I'm assuming you got this from a service manual online? do you have a link as i think itll come in handy and rather than my clogging up the forum :)
cheers :tup:
cheers :tup:
Not from an online manual, it's from a program called ElsaWin, basically a copy of the dealers manuals, avail on ebay for around £20~30 it covers all VAG models from 1995 onwards
cheers Nige - i used to use Servicebox for my old peugeot - simply log in to the website saying your a company based outside the EU and it was free, will look into that later
thanks once again
thanks once again
No probs
